The harness is available for 60$ and upgraded tow mirrors are coming to replace all small mirrors and tow mirrors on the new body style later this year. My understanding is that they will include power/heated/blind spot.
  • 5 weeks later...
excited! sitting tight for this. I really need power folding tow mirrors.
    DaleB
    DaleB
  • Who's Online   2 Members, 0 Anonymous, 1,276 Guests (See full list)
