Hi Everyone,
We need the following testers for our new developed taillights :
1) Halogen OEM taillight  Silverado 19'-20'
2) LED OEM taillight Silverado 19'-20'
Please  contact via email : [email protected]
We only have 1 set each model, please send over your current setup picture for reference.
Best Regards,
Tony@AnzoUSA
Update
We got LED model tester, now we just need Halogen model tester !
Please feel free to contact me for details ~ You will get to keep the testing set for free 👍
