Hello, If someone could give me some advice that'd be wonderful. I own a 2014 Chevrolet Silverado 1500 5.3L and im purchasing a straight pipe/standard exhaust converter. the converter requires a vacuum line to tap into, anyone have any ideas? thank you
  • Confused 1
What?
There are basically zero vacuum lines on these engines. The only two lines that go into the intake are for the PCV system.
You can't run a vacuum line down to any part of the exhaust, that would create a vacuum leak and to be honest I have never heard of an exhaust converter needing a vacuum line.
15 hours ago, CamGTP said:
its a converter from ECSTuning. they are designed for European cars but the universal system in the link works with any vehicle if it has a vacuum line you're able to tap into so you can swap from straight pipe to regular exhaust in the press of a button. https://www.ecstuning.com/b-ecs-parts/build-your-own-universal-vacuum-actuated-exhaust-cutout-kit-single-cutout/020923ecs01~dk/?pdk=AAAAAQQEAQ
So it's a cutout, not a converter.
You can run a vacuum source down there from the brake booster line. You should be able to find a "T" fitting with two large nipples and a smaller nipple so you can run a line down to the cut out.
  • 2 years later...
There is a vacuum line on the passenger side, mine is leaking, behind the intake and manifold, tryna get to it, found it while I was under the truck on my 2014silverado, caused me all sorts of problems
Im having problems with locating the hose behind the manifold because I’m having that same problem on my 2017. Where exactly is that hose connected to?
I cleaned mine and then ran a 4gauge wire with it because I have a Rockford fosgate power 1000watt and jl 400 amp, and clean the one under your alternator, and driver side wheel well to
The hose is a transmission breather vent along side of the transmission, the other one is a ground next to the mud flap, and another one on the driver side same position
