My truck has been acting a little funny lately. I haven't been left high and dry yet but you never know when it will get worse all of a sudden.
Symptom 1: If the RPMs drop suddenly after the engine being under load for a while, the computer throws P0332. This usually happens when canceling cruise control on the highway. I took a road trip last weekend and it happened 4 times in 3 days. Every time was cancelling cruise. I would reset it with my scanner at the next stop each time. It doesn't happen every time cruise is cancelled but enough to be noticeable. (The knock sensors and their wiring harness were replaced recently with good Delphi units)
Symptom 2: Twice in the last month or so I'll be driving along and the dash lights up like a Christmas tree. Every light. The first time it happened at the same time as the P0332 with cancelling cruise, the second time it was all on its own. It threw maybe a dozen codes each time. Some of them were U1041, U1026, P0446, P0327, P0060, P0059, P0054, and P0053. I don't have all of them written down but that's the general idea.
My first thought was a ground and I've checked a few but the problem was not affected. Are there grounds I should definitely re-check? Does anyone know which grounds these sensors and modules are connected to?
Alternatively, is this a bad ECM/PCM?
New symptoms:
-Fuel gauge will go to empty and the low fuel light will come on. Stays that way for several minutes and the comes back. No codes. (Fuel pump assembly replaced in January with new Delphi, gauge cluster is new in September 2020)
-Battery warning light comes on but voltage gauge acts normal. Truck runs normal. Light stayed on until ignition cycled. No codes.
-Service 4wd notification comes on in DIC and stays on until ignition cycled. No codes.
-Airbag light comes on solid. Stays on for a few minutes, goes back off. U1088
-Gear indicator light and transmission respond several seconds after moving the physical gear shift lever. Only a few times. U1026.
It seems like a computer issue to me. What do you guys think/which computer?
IMO
Electrical issues require an elimination process.
Instead of guessing start with grounds. Find them all and redo them to make sure they are not the problem.
Is the battery good?
I did check some of the grounds. As mentioned above I was also interested in which grounds are relevant to these issues. If you have a comprehensive list of grounds for a 205 Silverado 1500 CCSB, that would be helpful too
I got a freeze frame of the P0332 code from my scanner (innova 5410) The pictures didn't turn out well so I'm just going to type out the results. This occurred after driving on cruise (set to 68) for approximately 10 minutes and then cancelling by tapping the brakes lightly and coasting. Do any of these look off?
Fuel Sys 1 - CL
Fuel Sys 2 - CL
Calc Load - 13.7%
ECT - 203 F
STFT - B1 0.0%
LTFT - B1 0.8%
STFT - B2 0.8%
LTFT - B2 3.1%
MAP - 6 inHg
Eng RPM - 1603
Veh Speed - 63 mph
Spark Adv - 27.0
IAT - 70 F
MAF - 1.21 lb/min
TPS - 14.5%
The other issues are still happening intermittently. This is by far the most common symptom, I cant figure out why it's happening. I rechecked the connection where the Knock Sensor harness plugs in the main harness, I rechecked the main harness ground to the firewall.
Edit: The truck also threw a P0327 which (along with the other above symptoms) leads me to believe that it's not just a faulty replacement knock sensor
Edited by Ian Mills
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 442 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
