grill swap
i have a 97 1500 w/t and it has the gray plastic grill with the sealed beams is there any way i can install the other grill from same year/body style with the differnt head lights also i have the rims from the ss454 they are 15inch what tire would fit them the best
thanks
If you have a 2wd, I would say that the 275 x 60 r15 looks the best on there if you are staying with that diameter.
By w/t, I'm assuming that you are talking about a "Work Truck" , and by that, you are indicating that you have the single headlights? Not the 4 that the Silvarado came with?
Not sure if a Silverado front clip would go, but if it does, it would more likely than not be a bolt-on/plug-and-play sort of thing. Other than the extra headlight wires.
Just get a Denali clip, and call it good. :P
JP Customs sells them, and they are preferred vendor here.
www.sporttruckingstore.com/Detail.bok?no=4774 was wonderinding if this would work its cheaper and mor of what i was looking for
