Just a couple pics and thoughts.
1.  BAK provides an addendum for installing this on a carbonpro.
2.  These instructions replace the first 5 steps of the normal install directions.
3.  If you follow these you won't install the front box seal.  Do that first then follow the addendum.
4.  The locator tool used as a drill template is nice...but the ears prevent you from getting a good solid lock on the unut.  Just take your time.
5.  Use a ratchet wrench to greatly speed up the task.
6.  Bumpers are basically useless on this install.  Don't see anyway the cover will hit the glass when rolled up.
7.  Much improved over the original roll-x.  No slag from the machining process, no felt on the inside and nearly OE fit/finish.
20210625_141758.thumb.jpg.67485e2cad5adfb989397d9be0a4268a.jpg20210624_185333.thumb.jpg.1178b900e21a02b08af6bef06b3109f4.jpg20210624_185327.thumb.jpg.b6e6136fc967d0d968822d84935286e9.jpg20210624_162315.thumb.jpg.48484ec18999ff9e07b8a0da20c75581.jpg20210624_160140.thumb.jpg.60ed63c1076dcee4958fe02a670d565a.jpg
    CaptainDad
    CaptainDad
  • Who's Online   2 Members, 0 Anonymous, 598 Guests (See full list)
