23 hours ago, Scooby-Doo said:
Obd2 codes
Welcome to the site.
Guess you were looking for a meaning to the code:
P219A CHEVROLET Meaning The Fuel Trim Cylinder Balance diagnostic detects a rich or lean cylinder to cylinder air/fuel ratio imbalance in each bank. The diagnostic monitors the pre-catalyst heated oxygen sensor (HO2S) signal's frequency and amplitude characteristics by calculating an accumulated voltage over a predetermined sample period.
P219A CHEVROLET Possible Causes What does this mean? Leaking or contaminated fuel injectors Low fuel pressure or running out of fuel Leaking evaporative emission (EVAP) canister purge valve Exhaust or intake air system leaks Exhaust gas recirculation (EGR) system Positive crankcase ventilation (PCV) system is leaking or the valve is stuck open Ignition system Incorrectly seated engine oil dipstick, tube or oil fill cap
Read more: https://www.autocodes.com/p219a_chevrolet.html
