Looking to run this wheel and would like to run a 35" tire on my current stock AT4. Has anybody tried these wheels? Will I need a level kit with UCA or a lift to do so?
Product Info
Venomrex 601
20" X 9"
ET0 (Chevy/GMC/Dodge)
Mystic Black
Flow Forged All Terrain Wheel
Wheel Specs
PCD: 6X139 (Chevy/GMC/Dodge)
Offset: 0 (Chevy/GMC/Dodge)
Backspacing: 5.0" (Chevy/GMC/Dodge)
Bore: 106 (Chevy/GMC/Dodge)
Load Rating: 2,600 lbs
Specs
PCD: 6Xhevy/GMC/Dodge)
Offset:(Chevy/GMC/Dodge)
Bore: 87
I know the specs on that wheel are same as the stock 20" but can't confirm the back spacing?
I know there is one person on here who runs Venomrex 601s. They are running 285/60R20s and still had to do the mud flap trim on a stock AT4. That’s a 33x11 inch tire. I am running a similar wheel and tire setup: Vossen HF6-4 20x9.5 +15mm, but I’m on 275/60R20s which is a 33x10.8 inch tire. I have a non-X31 Elevation that is lifted/leveled 3”. So that would be similar to a leveled AT4. I have no rub, and really not much room for more tire without modification to the wheel well. To get a 35” on there you’d probably need a 4” lift on top of that 2” lift - I’d say no way you fit 35s stock or even with a level. BDS makes a 4” kit that will stack with your AT4s factory lift for 6” overall. It’ll be pricey though.
    C. Hart
    C. Hart
  • Who's Online   2 Members, 0 Anonymous, 476 Guests (See full list)
