Hi guys,
I just bought a brand new 2004 Z71 extended cab. After owning the new dodge ram for a year I could no longer deal with all the problems that I had with it.I have alwaya owned chevys and now Im back.
My question is,I have the 17" wheels with the 265's.Does anybody know the largest tire I can fit on them without rubbng. I was able to move up to 285"s on my 94 Tahoe and would like to do the same here.
Will they fit?
thanks...
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 1,193 Guests (See full list)
