Hi All,
While I was looking at upgrading my headlights to LEDs for my 2015 GMC sierra 1500 Elevation, someone told me to swap it with 2016 GMC sierra 1500 assembly.
Since most of you guys have more knowledge in GMC trucks compare to me, Are you guys able to confirm that 2016 assembly will fit my 2015?
Appreciate all your help!
Thanks,
    thefultonhow
    thefultonhow
  • Who's Online   6 Members, 0 Anonymous, 685 Guests (See full list)
