Got bored...
pacodiablo
...and spent a ton of money at the local hobby shop and built this over the weekend and today...
You and I have really different ideas on what constitues a "ton of money". :thumbs:
Looks :cry: though....Is it supposed to be a Yota?
Thanks for the comments everyone!
I ran into some trouble with the flatbed...the d**n thing will not stay on the truck. I think the frame and/or bed are not level, and/or the plastics are different and not bonding because of it.
I will go to the hobby shop soon and see if I can find something to use as a bed.
BTW - the original pickup bed was damaged, which is why I put the flatbed on.
If the bed doesn't line up properly with the frame, I would take it back to the stealer....Should be a warranty item.
Unless you bought it used, it could have been in an accident....Did you run a carfax on it?
:thumbs:
LOL.
I was the one who screwed up the pickup bed. :thumbs: The paint went on the body fine, but I had a lot of trouble with it on the bed. I tried again, but I don't think it will come out as good as the body.
I should be able to find some sheet styrene (the plastic used to make the models) and scratch build a flatbed. If I can't find that I could use thin metal and balsa wood.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,164 Guests (See full list)
