Hello everyone. I have a question about the 3rd brake light on my canyon. When I push the brake pedal the 3rd brake light flashes 3 or 4 times and then it stays on. Is there a way to keep it from doing that? I would like for it to just stay on and not flash. Thanks for any info
  • 3 weeks later...
Did you buy the truck used? Sounds like someone installed a motorcycle brake light flash warning circuit in there.
The high mounted center stop light is on its own circuit, not directly tied to the L and R stop lights.
