Vehicle- 2002 Workhorse P30 FT1461 bread/box truck      5.7L   130k previous running condition
Condition- Cranks strong, Spark, No start
Problem- Moved vehicle one day and came back a week later and had a no start. It was moved on a sunny 80deg day so it wasn't in a flood or some other crazy situation.
                Scanner shows no codes, cranks strong scanner shows about 175 rpms next checked spark- good spark plugs DRY. Checked fuel pump, pulled and cleaned screens although                    they were not bad. Pressure at check valve on top of intake is 62ish psi with key on and then 58-60 psi cranking. All fuses checked good. Pour gas or starting fluid into throttle                  body and it runs properly until it is burned off. Will not stay running once burned off. I then switch spider injector assembly (regulator is part of it as well) with a known working                    one with no change.
               No idea on how to proceed or if I am missing something easy, trying to find which wires are the signal wires for injectors to verify if they are getting a signal or not and that                         would lead me to believe it is a ecm/ecu problem.
Edited by UA Limos
    daveishi
    daveishi
  • Who's Online   1 Member, 0 Anonymous, 894 Guests (See full list)
    • Because that is IDIOTIC, much like this question. They've already been forced to do it by past administrations - why would you roll that back when it's a GOOD thing?  WHO IS ARGUING FOR LOWER MILEAGE???? 😂  NOBODY IS!!   I'm certainly not! What I want is RELIABLE vehicles again that are worth the price paid!    I don't get your logic here ...   In 2003 I paid $2,200 for our '86 Grand Marquis. It's STILL running and I've never been inside the engine, aside for the timing cover since it was leaking, so I threw a new timing set in since that makes sense. Transmission is ORIGINAL. Electric pump in the gas tank is ORIGINAL. Rear end is ORIGINAL. I'd have to hit my head REAL hard to want to pay $60k or more for a car that still can't come close to the comfort, seating and storage space, or reliability of this one. Nothing is even in the ball park! Hundreds of thousands of brands and models have been built and sent to the crusher while this one keeps on going!   https://postimg.cc/Z9XRrCSg   I've got a whole fleet of cars, motorcycles, and a truck close to this age for summer and winter. No one could pay me enough to buy anything built this century. I have zero use for any it.
    • Since I'm the one who has to fix them when they break, I'll take vehicles over 30 years old all day, EVERY day, over ANY modern crap. Have you attempted any repairs on anything built after 2006? It's a friggin nightmare, and gets worse the newer the model year.    If I had the will or desire, I can make any car of any age outside of a Model T (I don't have THAT much will ...) just as powerful, comfortable, and have all the tech the new stuff does, and get pretty close in mileage, too. I prefer SIMPLICITY. The less the vehicle has, the less to fix WHEN it breaks, not IF.   I'm glad you snot-nosed punks don't like them. More for us, plus that keeps the prices from climbing more than they already have.👍
    • Bringing this thread back on topic. I just noticed the incredible lack of bright chrome across the entire new lineup. Even the Denali has tinted the brightwork in the grille and has none elsewhere. None of them have chrome bumpers. As far as I can tell there aren't even chrome mirror caps. I'm curious if this also happens out back? Are there no chrome rear bumpers either? This is quite the departure for GMC.
