Hello. I have a 2000 GMC C3500 cab and chassis with 5.7. A couple of weeks back it needed a cap, rotor and plugs, plug wires. I replaced and the truck would start and run fine. I completed a compression check and all cylinders were within specifications and within 10%of each other. I now have a no crank issue that is described as follows. The engine will spin over and sometimes catch but the firing is only helped by the starter. If it does fire it idles extremely rough. I was able to get the engine up to 2500 rpms and held it there to see if it would improve. Timing on my scan tool showed 36degrees advanced engine would run but off smell in the exhaust. Not the rotten egg smell of a bad converter. Bumping the throttle causes the engine to stumble and it sounds to me like the timing is off. It runs ok at 2500 with a slight miss. I pulled plugs they are wet with fuel. Fuel pump comes on with key, runs when key is turned off. I have pressure at the fuel line. I have spark at the plugs. I have the following codes. P0108, P0125, P0141, P0157, P0161,P0338, P0462, P0463, P1106, P0108, Pending was P0157.  I used a ohm meter to check the crank sensor ohm values and found that I had 7.62ohms between the yellow and blue( middle) wire when homing the sensor out. I had 12volts going to the sensor as well. Thoughts?
first thought, you said you needed a cap, rotor and plugs.................. how did you know you needed these?  Try putting back your old cap and rotor, and see if your issue is solved. Plugs......... make sure they are gapped right and they will last a very long time.
Plugs were gapped to the specifications in the manual. How is I know I needed plugs because they were worn out electrodes were gone. Cap was shot and rotor was worn out as well. Plug wires ohmed out to high of resistance. So these were replaced and the truck drove fine four the last three months. Just started having issues and drained and refilled with fresh gas. Still not running right.
I could still use help with this truck. I replaced the MAF sensor as the sensor didn’t test out. The truck started and ran about 15 seconds perfectly. It then began to idle lower and rough I jumped behind the well and hit the throttle engine was sluggish to respond but eventually climbed to about 2500 rpm and I tried to keep it there. It stayed running as long as my foot was in the gas, it sounds like it’s fighting itself though while running. I then let it try to idle it just died. Cranking it over it Carl’s like it wants to start but not enough to keep running unless the starter is spinning it. Pulled plug after this incident and the plug is black. Ckp sensor?
Have you checked for cross-firing inside the cap? If you went aftermarket,  sometimes the cheaper caps will cross fire pins inside the cap which will cause several of the symptoms your experiencing.  Also fuel pressure at rail?? Definitely find out what the pump is actually pushing...
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
