14SierraSLE5.3L
Short hand summary.
-Cold air quit, popped hood, ac belt shredded and melted.  Melted to only a third of the compressor pulley, but 100% of the balancer (suspected compressor locked up).
-Cleaned pulleys, replaced belt, compressor pulley spins freely (doesn’t have typical clutch that remains stationary when not engaged).  No cold air
-Pressure looked low (hard to say when you don’t know if the compressor is engaged), tried adding some 134, it took some from the can, then killed the motor.  Suspect the compressor engaged and the drag from the belt stalled the motor.
Before I replace compressor and the works, any suggestions on testing the system/compressor.  The non visible clutch is really throwing me for a loop.
Hey i am going through the same deal. The compressor is toast as in locked up. I am not sure which repair route ill go as I have lifter issues as of yesterday...
Id suggest compressor, lines, metering device and filter. Its just the compressor likely tho.
This is an important question.
Before it failed did you notice a snatching sound when the ac turned on first start?
I’ll do the works (compressor/condenser/orifice tube/dryer/etc), but first I want to be sure it’s not something petty like a hi or low side switch.
The only thing I noticed was the day before after hauling my boat for 4 hours there was some “smoke” from under the hood.  Didn’t find leaks and it wasn’t obvious to be coolant or oil (however I didn’t think to look at the belt).
I’m still trying to figure out how you know when the compressor is engaged, it’s not like any previous ac clutch I’ve seen.  The entirety of the pulley is always rotating with the belt, whether the AC is off or on.
The hp or lp saftey switches only turn off the comp. Not lock it up.
I'll suggest seasons4 for replacement parts. They have the vehicle ac stuff perfected.
I appreciate the suggestion.  Do you know anything about the clutch on these compressors?  Typically the center of the pulley is clutch location and is stationary until it engages.  Mine is not engaged, but the entire visible assembly spins freely??
I do not know what's up with the clutch. I'll pop the hood tomorrow and see if mine spins as well. I didn't really care atm as I was pissed lol.
Just confirmed on my 15 LT 1500, the AC clutch engage only when AC is on. It spin freely when not engaged. There's nothing special about the AC clutch.
Sounds like your AC clutch locked up.
Can you post a 2 sec video?  Doesn’t sound like the same compressor.
Will do when I'm off work. I have a 5.3 1500. The compressor clutch look the same like any others I worked on before. Same concept, engage when it's on, disengage when off.
Take a picture of your compressor and clutch.
This is NOT engaged…I don’t see a clutch remaining stationary?
What looks like the clutch spins with the pulley AC on or off / HVAC powered off / set to heat (no defrost). I think I’ve confused myself more now.
21 minutes ago, CrawlSlow said:
The outer part is the clutch.
In that case it runs all the time, no matter what is turned off or on.  It doesn’t produce cold air, and evidently locked at some point to melt the belt.
    DM22
    DM22
  • Who's Online   2 Members, 0 Anonymous, 2,881 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
