I noticed that when down shifting (3-1) my transmission makes a clunk noise I searched the rest of the forums for
this problem and couldn’t find a solution. I’ve seen that on previous models that the slip yoke has been replaced to alleviate this problem but not sure that will fix this. Tia.
Edited by Tmac187
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
