22 minutes ago, DaddyBlue said:
Todd, is your 3500 4x4?  Did you have to add any transfer case wiring?  Did you leave the Escalade Electronic BrakesLarge plug unhooked?  I am currently working on a Escalade Platinum interior swap into my 2500HD Duramax 4x4.  I am looking for pointers.  Thanks Trevor
Two big things with the swap, the LBZ uses a high speed can line for the engine to trans to glow plug module connection that also goes to the obd2 port. I ran those into the escalade dash harness. Mine was not 4wd, but AFAIK you should just overlay the wires for the 4x4 switch setup and be fine. Second, I had to de pin a few of the wires from the large escalade brake / chassis control connector for the rear lights and abs stuff. The escalade i got my interior from was a 6.0 AWD model so the connectors might be different. PM me if you need more wiring help.
  • 2 years later...
Exactly what wires did you have to remove from the Silverado? Harness, and add to the escalade harness. Can you be specific
