Last minute warranty work
Last week I noticed the voltmeter reading about 17 volts all the time. Knowing there was only a week left on the warranty I bought it in. Sure enough the alternator had bad diodes. They put in a new one and I told them about the strange situation when idling thru a parking lot, as I attempted to speed up, there was now power to the wheels. They checked the codes and did a pressure test but found nothing wrong. They said maybe the tranny couldnt decide what gear it should be in or maybe the bad alternator was screwing up signals to/from the computer. I figure at least it is documented that it did happen so if the tranny has problems in the near future they may cover it. The guys said I may get a report card from GM and asked me not to blame them for the 10 or 12 things I had to have fixed over the last 18 months. They said blame the product, not us. I told them they did fine fixing things, cant hold them responsible for cheap parts used in the truck.
    appletrav
    appletrav
  • Who's Online   4 Members, 0 Anonymous, 294 Guests (See full list)
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
