2003 GMC Sierra I recently replaced my blower motor resistor and HVAC control module. I don't drive it much except for towing. Towing season is over and the truck will just sit. It doesn't more than a couple of days and the battery will dead. Battery is new, alternator charges fine.
A buddy suggested removing the NEG terminal and attach a test light to the battery post. The test light is lit so I started pulling fuses and relays but the test light stays on. On top of that I have no climate control whatsoever. Everything else is stock besides some LED lights that are switched independently.
Any suggestions on what else to look for?
Edited by HeadnSouth
If the truck is not used much, I would just remove the negative battery post when its not in use.
Well, diagnosing a parasitic draw can be really hard or really easy - just depends on what the problem is.
First off, start with a measurement of the milliamps.
Some draw is normal, like from the computer or the clock. Some rigs are 20, some 50, some 85.
Also, make sure that your hood light is not throwing off your readings.
You can start pulling fuses and relays.
You can disconnect the starter, and the alternator.
You can disconnect the computer or body control module.
You just start pulling all the electrical connections until you see a drop in milliamps.
Edited by Supreme Pizza
you could have a skinned wire that is grounding out somewhere.  The test light from the negative battery will stay lit as long as your security works, clock memory, bcm memory etc.  They rely on your battery to keep them on, but shouldnt pull much to actually drain the battery in only a few days time.  Faulty cluster panels can be a cause of this. To test that remove the cluster and let your truck sit for the time it normally takes to drain, if it starts, there is a good chance your problem is here.  After market radios are another big fault problem if not done properly.   I see you say everything is stock except the added LED lights though, so that shouldnt be an issue.
Edited by Sharpz
Thanks for your reply. I'll look at what you mentioned and come to think of it. It does have an after market radio and I did install a tailgate lock. The TL being the newest addition. I'll start there.
Put a Battery Tender on it.  A Tech-2 can run a parasitic draw test on most models.
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 443 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
