Does anyone know of an audio company online that makes line output converters for our trucks that have the factory plug already installed on it so all you do is plug it in to where the factory sub would be plugged in at?
Edited by Landonkw
    Gkistler
    Gkistler
  • Who's Online   5 Members, 0 Anonymous, 806 Guests (See full list)
