I recently put on 22' GMC OEM wheels with 275/50/22 tires.
Front driver side slightly rubs when turning left,
Front passenger side does not rub at all. Clears both left and right turns.
Is this an alignment issue or wheel well liner problem?
Those are off the new style trucks so a 33 inch tire.  The stock tires for your truck are in the 31.5-31.9" diameter range.
You will have to trim the fender liners at the minimum.  If you don't want to trim, you will need a leveling kit.
  • 5 months later...
Not related necessarily but I noticed the tiniest of scuff marks on my wheel liners with the factory 18" wheels and tires just the same.  I've never actually heard them rub, but obviously the small scuff marks say otherwise.
    appletrav
    appletrav
  • Who's Online   1 Member, 0 Anonymous, 483 Guests (See full list)
