2 hours ago, Duelin said:
Found this, I don't know how it is going to display or if it will help you.
89127323_ScreenShot2022-03-22at9_46_43AM.thumb.png.e791eac766c2f16babedebe7937863a3.png1645345442_ScreenShot2022-03-22at9_49_00AM.thumb.png.6e27bfb95ade1d3fd56bb0701450abd0.png857004504_ScreenShot2022-03-22at9_49_42AM.thumb.png.898c0c2a2a27cccea2b15c2bbc83f2bc.png
Awesome thank. But for example where is says upper ball joint then gives the spec it says 37/50 is that a torque between 37 and 50? Just want to be sure I get my truck back together with no other issues lol.
Where it says 37/50 if you look you will see ft-lbs/ nm.  The 37 is ft-lbs. The 50 is nm (newton meters). Hope this helps. If you run into this again there are conversion chart for ft-lbs to newton meters and newton meters to ft-lbs. Hope this helps and clears up the confusion. Don't know if you noticed or not but if you click on the charts it makes them just a little bigger.
Very helpful. Much appreciated.
    TopBo
    TopBo
  • Who's Online   0 Members, 0 Anonymous, 2,310 Guests (See full list)
