I have a 2009 gmc yukon it wont start but i noticed my alarm light staying on so i tried to reset it by turning key on position for 10 minutes and i repeated this step 3 and 4 times still nothing i also had a diagnosis and it said my ecu is disconnected i really need help
When you say it won't start, are you saying that the engine turns over but won't fire or the engine won't even attempt to turn? With your diagnosis, what codes did you have?
The engine wont even attempt to turn . i did a diagnosis and it said my ecu is disconnected but i connected all the wires and still nothing i even did the key reset and my alarm lock light stays on
What codes do you have? If the ECM was disconnected you wouldn't have communication with it and therefore no codes - other modules may have set codes saying they couldn't talk to the ECM - is that what you're trying to say?
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 901 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
