I know this might sound stupid but ive never done an exhaust change before so here it goes. Im replacing my stock exhaust with an mbrp and the v band clamp on the catalytic converter is preety rusted and i cant get a wrench on the bolt so im thinking im gonna have to cut it off all i have is an angle grinder and im just trying to figure out which way i should be cutting it so as not to damage anything?
Just cut the bolt off where it pinches the side together. Some kits come with a new clamp and some parts store sell that clamp as well.
    Dom Colussi
    Dom Colussi
  • Who's Online   4 Members, 0 Anonymous, 566 Guests (See full list)
    • *Your
    • I'd guess that it's because they are Mann-Hummel filters since about 2016, they own Wix and are mostly all made in China now.
