Hello,
Want to add some lights to the bed of my 2020 WT and can't find a diagram for the rear bus block under the bed near the bumper. I know this is where the trailer wiring plugs in but I would like to find a factory style plug to provide a constant power source because the lights will have individual on/off and Bluetooth capability.  Low current led so not worried about current draw. Any help is appreciated.
Thanks.
