I installed a set of aftermarket mirrors and followed the instructions that came with the harness and all the different videos I watched online and the white LED lights on the side of the mirrors stay on if my headlights are on. What did I do wrong and how to I fix besides cutting whatever wire it is. This is what I did:
Blue Wire-Running Light(Pin#11)
White Wire-Cargo Light(Pin#9)
Red -Turn Signal(Pin#41)
Why Does the light stay on when my headlights are on?
You didn't post the year of your truck. I am very limited on electrical stuff but have seen that the 14-15 mirror functions are set up differently from 16+ and different things need to be done. One guy who would probably have an answer for this is @pgamboa and maybe he will see this thread and respond...
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 817 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
