While driving at night, my car will flash from low beams to high beams on their own.  Just out of curiosity I put the lights on during the day, and the lights did the same exact thing.  Changes from low beams to high beams for a second or 2 and then back to low beams
    President Roberto
    President Roberto
  • Who's Online   0 Members, 0 Anonymous, 222 Guests (See full list)
