I have a 2018 Silverado LTZ with factory wheels. I purchased a set of take off wheels from a 2021 Sierra AT4.  Will I need new TPMS sensors when I install them on my truck?  Or will one of the TPMS relearn tools work to get me all squared away?
  • 3 months later...
