How senstive is your steering to varied
Hey all,
Just wondering how sensitive your steering is to varied road surfaces with respect to banked roads and crowned roadways. Here's why: Just when I think my '02 Tahoe needs an alignment 'cause it's pulling to the left (when riding in the left lane on many highways and whatnot), I'll find that it pulls a bit to the right when I get on some local roads. Based on this, I've been paying a lot of attention to when it feels like it's pulling, and I think it pulls to the side of the road where there's a slight decline.
Since most roadways are crowned to allow water run-off to the sides, depending on which lane I'm in, my Tahoe usually wants to wander that way. It seems REALLY sensitive to the road surface pitch. Anyone else noticing this?
Or...
...Maybe I really DO need an alignment. If it sounds like strictly an alignment issue to you, what could be causing the sensitivity? Toe in/out, or something else? I DO have Ford keys installed, and the TBs cranked a couple inches -- but I also had an alignment done AFTER this (but before the start of winter here in PA)...
Thoughts?
Thanks!
-Kirk
My truck pulls slightly depending on the crown of the road. It is not very noticable unless I let go of the wheel... then the truck will slowly drift.
My wifes van has a noticable and annoying pull in it, and I need to get it to the Honda garage to see what's wrong with it. I'm guessing she smacked a curb or hit a monster hole and it is out of alignment.
My 03 Hoe does the exact same thing. I just looked at my alignment sheet and it's only got 3 degrees caster, which is not much at all. Most cars have 5 or 6 degrees for straight line stability. I'll bet yours turns in as sharp as mine!
    ballencd
    ballencd
  • Who's Online   5 Members, 1 Anonymous, 654 Guests (See full list)
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
    • I'm putting in an A-pillar pod/gauges, and I'm asking if anybody can identify a (preferably) fuse for a switched power and illumination circuit on the driver's side interior fuse panel. Offhand, everything I checked with a test light was constant-hot, and I'd much rather uses a piggyback fuse. I can certainly find a wire, but I'd rather not half-tap.   Thanks in advance for any help.
