3 hours ago, 16LT4 said:
 I hadn't looked at the lifetime mileage in a year, and today noticed that it has gone down in that time due to the changes I've done to the truck.  28 is great for a full-size SUV.  The 400 mile average of 24 mpg was also only within the last year, not since new.  Based on the lifetime mileage, I don't think the PO used E85 and likely stuck to the goldilocks zone of 50 mph roads.  If I used 89 fuel, went back to lower-resistance tires, stock aero, and didn't tow-haul what I am currently, I'd get the lifetime mileage (and all the other displays) back up.  From the displays, you can see the "bests" of the last year; current numbers are low due to hauling a 2000 lbs of firewood, and sand/gravel on the current tank.  I've also only been locally driving the truck with stop-and-go and haven't done a good highway trip with it in a while.
So: at 90k miles, the lifetime was 30.4 mpg.  Now at 102k miles, the lifetime is 26 mpg.  also don't forget, those figures are also under-reported, as I didn't have the speedometer corrected when I added the bigger tires; it is off by a few mph compared to GPS.  So, the 26 is more like 27 mpg.  And that's on E85 for the last 3+ years. 😉
Nice certainly good mileage for a v8 pickup
    ChristopherDobson
    ChristopherDobson
  • Who's Online   0 Members, 0 Anonymous, 1,087 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
