I have a 2017 sierra 1500, 5.3l. I am entertaining the idea of swapping out the regular chrome bumper with the paint matched Denali bumper. Does anyone know if they are a direct fit between the SLT and Denali? Thanks.
    Dom Colussi
    Dom Colussi
  • Who's Online   5 Members, 0 Anonymous, 586 Guests (See full list)
    • *Your
    • I'd guess that it's because they are Mann-Hummel filters since about 2016, they own Wix and are mostly all made in China now.
