My 2018 Silverado touch screen will randomly scroll, change channels and cycle through apps. Is there a fix for this?
thanks
Ralph
Screen digitizer is more than likely the cause. I tried all kinds of remedies to no avail.
Opuradio.com $238 plus shipping
let me know if I can help further
    • *Your
    • I'd guess that it's because they are Mann-Hummel filters since about 2016, they own Wix and are mostly all made in China now.
