Open Club  ·  281 members
diesel 3.0
So I have 19' 5.3 RST w/ 28k miles and I have been looking at ordering a 23' RST 2/ the 3.0. I just saw a 2020 RST exact same color as mine w/ the 3.0 but it has 42k miles, I have heard people having issues with the rear main seals leaking, my brother-in-law has a sierra 3.0 that has a small oil leak somewhere so I am hesitant now on these engines. Are they reliable and that much better than the 5.3? I have a travel trailer that is about 4,500lbs that I pull so I thought the 3.0 might be a better option for fuel economy but curious to hear real world experiences.
  • 2 years later...
I have one absolutely love the truck, but I had to dread it oil leak finally got it dealt with and my transmission had a little chatter at 150,000 miles. I got them to warranty the transmission and why they had it out. They did my timing belt, cause it’s in the rear. My oil leak was coming from my valve cover. I think all data is 12 hours to tear everything down to get to it and then assemble it but now that they got all the leaks fixed or while it was a part day, silicone front and rear plugs that are known to leak. So far 2000 miles and good with a total of 153,000.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,271 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
