GMC 2500HD vs. Ford F250
More Throttle
In the next few months I'm planning to get a truck to replace my car. I'm kind of torn between the GMC 2500HD and the F250 (both gas-engine - hopefully big-block if I can find one). For those of you who have experience with either of these, what did you like/dislike about them? What were the strong and weak points of each truck?
Sorry this reads like a college final exam, I'm trying to get as much info as I can,
and any info would be appreciated.
Thanks
If you are buying the truck to replace a car, do you really need a HD? Unless you're towing more than about 5,000 lbs. or carrying really heavy loads or have a slide-in camper, I'd think a 1500 pickup would be better suited to daily-driver functions. A 1500 would give you better mileage, better ride, and lower step-in height. Also, if you're married, I've witnessed that the wives in truck-owning families are much more accepting of the 1500 trucks than 2500 trucks.
hopefully big-block
With the Ford you have the choice of the 5.4 small block or the 6.8 V10. They dont have an actual big block. Now on the other had the GMC does have the 8.1 big block which has more power than the 6.8(10 more HP and 15 more ft lbs torque). I dont think there are really any bad problems with the Ford Super Duties (well gas powered at least) What I can say is that I have driven Fords, and I have driven GMs. You wont find me in a Ford. :rolleyes:
Now that sounds like a good reason TO buy a 2500! :rolleyes:
Here's the positives on each on each make the way I see it:
2500HD: Smoother ride, better interior and dashboard layout, more room in back if it's an ext cab, Allison tranny (if you get the 8.1L).
F250: Sits higher/more frame clearance, solid-front axle, auto/manual hubs on all 4x4 models, split-rear seat in ext cabs, enough room to mount lager tires without lifting or trimming.
As far as engines, Ford is kind of weird with what they offer. What I mean is that the base engine is the dependable but comparatively weak 260hp 16-valve 5.4 V8. Ford just introduced the new 300hp 24-valve 5.4 for the new F150s but you still can't get the upgraded engine in the F250/350s!! So if you are opting for the base engines GM has got Ford beat bad right now with the 2500HD's base engine in the 6.0L.
As far as the 6.8L V10 vs. the V8 8.1L, GM has also got Ford beat but not by a very wide a margin. The best reason to go for the 8.1L, in my opinion, would be to get an Allison transmission. I know the 8.1L wins the towing war but the V10 is not a weak engine by any means & fills a niche with it's "mid" size. It's perfect if you want more power than a GM 6.0L or a Dodge 5.7L but don't need or want a "big block" engine. Both engines are turning out to be dependable and have plenty of low-rpm power (a rare quality nowadays) for towing. Honestly, I can't see a reason to base picking a Ford or GMC based solely on choosing between these two engines.
Thanks for the input.
As far as going to the 1500, I guess I just like the HD versions better. Don't really care for the 1500 looks as much as the "beefier" looks of the HD. Also, I plan to keep the truck for a while, so I'd like to have something that's ready for anything (not that the 1500 wouldn't be capable), I tend to overprepare for things...
Since the GM 6.0 is more widely available, that's probably what I'd get since I'll buy used. Ordering an 8.1 HD would probably be close to $40K, too high. I've seen newer used 2500HDs with the 6.0 for around mid-$20s.
I've heard of the F-250 having a harsher ride than the GMC, so that would figure into the decision, as it would be a daily driver. I guess it'll depend on what's available at the time I'm ready to buy.
Definatly shop around. We got the 03 Duramax/Allison in July with 12,000 miles on it for 26.
Wow, that seems like a very good price. Did you buy from a private seller or from a dealer?
  • 3 months later...
F250. I just drove a lifted '04 F250 with the 6.0 PS from Mustang Island to Dallas and it was soooo nice. The interior is rather bland but the ride and cabin size was really impressive. I can't believe I like this truck better than mine. :)
Both trucks have pros and cons. The biggest seems to be the Chevy is more car like while the the Ford is more truckish. Anyone could be happy with either truck.
  • 1 month later...
I test drove a F-250 w/ the 5.4L about a month and a half ago... I didn't like it. If you go with the F-250, avoid the 5.4L.
As much as I hate to say it (I am not a ford lover) the 5.4 with 4.10 gears ran pretty good in the ford I test drove. Ford is more of a truck and chevy is more of a car and has a lot lower frame rail clearance than ford and for the life of me I still cannot believe why they did it but the brush and rock catching cross brace BELOW the main frame rails under the cab on the NBS GM trucks and lower clearance even more. Even OBS GM truck had those cross braces tucked inside were it belongs. If you want a car like truck buy a GM if you want a trucky truck buy a Ford. I love GM truck but they seem to have lost focus a bit.
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 914 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
