454 vortec - replaced a lifter after I got sick and tired of the ticking noise it was making, that Ofcourse means I had to pull the intake and distributor, after the swap I put the intake back on and installed the distributor, I didn’t think to mark it when I pulled it out so I brought #1 cylinder to tdc compression then installed the dizzy so that the rotor would point to the number one point, put everything back together and now cranks but no spark. I’ve spent the past couple days messing with it and at this point am at a loss, I pulled the top plenum and plugged all sensors in and such, coil and the cam sensor. The injectors will pulse and when I put a multimeter between the plug wire and ground I will get a fluctuating voltage. But no spark, and help is appreciated and thanks in advance
first post here so let me know if I left anything out,
kevin
Check the coil for power and a ground pulse. if that checks it's the coil, if no pulse maybe ignition module is bad
I checked from the plug to ground and it read 12v with key in ignition, and would load-safety my multimeter when I cranked it over, it’s a 1000v multimeter
So if it has a good primary but still no spark you have a bad coil. the spark would be over 50,000 volts and with the coil wire disconnected from the coil should arc to the coil body or bracket if the coil is healthy. If you have good spark at the coil suspect the ignition rotor. An inline spark tester is an inexpensive and handy diagnostic tool
I will be picking up a spark tester tomorrow, I just checked the primary and secondary resistance on the coil and everything is on spec according to my Haynes manual
Does the coil timing have to be spot on with when the rotor passes the point? Just cranked the engine to see the coil arcing to ground consistently
No. Examine the ignition rotor for a burn mark or carbon arcing, also the dist cap. when I reset a distributor the rotor should be pointing straight forward if it's up on # 1 compression stroke, there should still be timing marks on that engine. you will need a TechII or equivalent scan tool to set the timing but you can get it close with a timing light
Edited by richard wysong
Here’s the rotor, I gave everything a quick sand before it got put back together, I find it very strange because everything worked fine before I took it apart
Well you are losing the spark somewhere between the coil and the plugs. Bad coil wire? Remove the rotor and look at the bottom for a burn mark, closely examine the dist cap for damage to the coil connection and carbon tracking.  Are you sure there is no spark at the plugs? I guess when you get your spark tester it will be easier to determine. You are sure it was TDC #1 compression and not 180 out when you dropped the distributor in?
UPDATE:
picked up a brand new distributor, plugged her in still no cherry, I pulled the cap off and between the center hot electrode and ground I get a good strong spark, but then from the #1 cap plug to ground nothing, even if I shove a regular wire in it.  It seems like the cap might somehow be shorting to ground somewhere. The plot thickens haha
Did you check the rotor? Spend the $10 and put a new 1 on. You replaced the distributor or the dist cap? The spark is shorting to ground through the rotor most likely
Brand new rotor and cap came with the dizzy
Well that only leaves the wires as a possibility. Why did you replace the distributor? you had spark at the coil. Is the distributor turning while cranking?
Yeah distributor turns while cranking, I put a new one in because the old one has a good amount of play. I’ll mess around with it for the rest of the afternoon and see what comes up
    • Maybe, but it seems he is the only one that has backed up data to prove what he is stating. I think he is doing this more because he enjoys it and wants to get the information out to us. He's got the knowledge and access to the proper equipment and having the funds doesn't hurt.  I would love to do what he is doing and would do it if and when I hit the Powerball.  I'm not a Tribologist by any means but love to learn what I can.   I would bet there would be doubting people out there if a completely independent lab with high quality work and highly respected in the automotive industry, put out information like this.  The world can't be pleased, one just has to take the information that they are given, do more of their own research to find actual lab data to back up what they are trying to figure/find out.  Most don't bother, they just want to believe what they first see.     I don't have the minimax but my 6.2 in my 2019 Silverado with 64k miles shows excellent UOA results with 0w-20 and for my own purposes 5w-20.  Since not much of a change using 5w. I liked the data sheet information on the SS 5w-20 and figured I would give it a try.  Still the same viscosity at 100℃.   In the end we all just do what makes us happy, life is too short to get upset over trivial social media.   On a side note, I do feel GM has dropped the ball and just cares about the bottom dollar and not quality anymore.  "Like a Rock" has been long gone.  Seems "Built Ford Tough" has as well.
    • Better than stock but that's like putting lipstick on a pig
    • Hello, my 3 month old Sierra Elevation wont recognize a trailer with electric brakes? All the lights work correctly, but no power to the brakes?   This is the factory installed brake controller. If you manually push the knob, the display shows the power % but does not light up like my 2022 silverado.   I have an appointment with the dealer, but was checking to see if anyone else has seen this issue.    Thanks,
    • Been using SS 0w-20 from new, but wanted to change to the 5w-20 because I liked the data on the data sheet, to me it seems like a little better product. But as you can see, not much difference. This is also with running a mix of 10 gallons E85 to a tank topped with 93. It isn't a flex fuel vehicle so any higher I get a CEL for running lean on both banks. Yes my mileage takes a hit. Instead of 20 mpg I normally get on trips I get 17mpg. This is also using EaO17 filter.  What is amazing is I have the AMSOIL cone filter on it since I have the GM Performance intake installed and that air filter has 44k miles on it.  I just take it out and shop vac it off once a year.  I use the upholstery tool on my shop vac.  Works well.
    • So, lot's of googling and reading, and a trial fit found, that indeed they hit the newer fatter caliper. I did some re-testing today, and found just 3/16" worth of washers was enough for the wheel to spin freely. I added 2 more on each, and again it spun freely. Tested lock to lock with the 4 washers, about 5/16" not quite the 3/8" Im considering, but pretty close. No issues. I've been looking at the BORA .375" spacers and using extended lugnuts to get back lost thread due to the spacer. All the ET lugs I've seen are all .33" reach inside the wheel lug holes. For those that don't like spacers or think they're unsafe, I think it depends on what type of spacers you're using and making sure you get good quality hubcentric ones, and if you're using bolt on ones, regular mainenance, checking the spacer lugs. Not wanting or needing that much spread. Looking for the minimum that will let me run these rims and tires.  it does look to stick out a little, but I really want put these on. and use the stock all-terrains in the winter.
