21 hours ago, richard wysong said:
How you making out?
SOLVED:
ended up pulling out the parts cannon and threw a new coil in it even though the old coil tested good, sure enough that’s what it was, the spark must have been just weak enough to not be able to gap the rotor to the points,
truck runs and drives now but still falls flat on its face if I’m idling at a stop light for more than 10 seconds, idles fine and there no cam timing codes, fuel pressure tested at 50 psi at idle, I’ll probably do new plugs because it’s been 50k since my last change and go from there, I’m living in the city during the week for school so I’ll live with it until the weekend
i should add that if I’m stopped and hold the break/gas so it stays around 1000rpm it won’t stumble, when the truck stumbles it’s so bad it seems it might stall right in the middle of the road
That could be the TPS or possibly a vacuum leak , if you have a scanner that does live data it will help with the diagnosis
I had the scanner hooked up yesterday, tps readout seems good, bank 1&2 long term fuel trims we’re high while cruising. I didn’t check what it did when it was having the issue
That would indicate that it,s running lean so maybe a vacuum leak? Pull the PCV and the breather  from the valve covers and see if there's vacuum in the crankcase, maybe an intake gasket slipped out of place
Thats what Im beginning to think aswell. Sucks that all my tools are at home, I’ll try to get home tomorrow and do some digging. I’ll let you know what the results are
I managed to run home quick to run some tests, testing vacuum from the manifold it’s a steady 17inHg, increasing when i apply throttle, fuel trims slowly creep up after snapping the throttle, cleaned the mag sensors then all fuel trims are in spec, truck doesn’t stutter or bog when the maf is unplugged..
check for a leak between the MAF and the throttle body. There was a post a while ago of similar symptoms and the OP determined the cat was partialy clogged causing the stumble. That may not be your case where the vacuum increases with throttle though , You could remove an upstream 02 sensor to check the back pressure
Edited by richard wysong
I will check for leaks Tomorrow, truck has headers and a full exhaust with no cats so it’s not a flow problem
Checked for vacuum leaks today, sprayed some ether by all the gaskets. Looks to be a tiny leak by the egr valve and next to the throttle body, I spent a hour getting all sorts of fuel trim readings so here’s the list
maf unplugged at idle fuel trims good
mag plugged back in, truck still running, fuel trims good maf reads 4.24g/second at idle
as long as the truck stays running since the maf was plugged back in the fuel trims stay good when driving
truck shut off and restarted with maf plugged in, fuel trims good, maf reading 9.05 at idle
drove around the block, maf plugged in, fuel trims very high, maf reading 4.62 at idle
I will get some gaskets on order and do new plenum, egr, and throttle body gaskets, plenum gaskets have been removed and reinstalled a fair few times so it could be leaking in the middle by the injectors aswell
  • Thanks 1
    • Thanks, all. It sounds like keeping the software "as is" is the best course of action.
    • https://en.wikipedia.org/wiki/Overengineering   Excerpt from the above link: (BTW the above is a 90 second read)   [Quote]   A story about very precise engineering is given in the 1858 story The Deacon's Masterpiece or, the Wonderful "One-hoss Shay": A Logical Story by Oliver Wendell Holmes Sr., which tells of a carriage (one-horse shay) Because it had been engineered so that no single piece failed first – no piece was over-engineered relative to the others, and they thus all collapsed at the same time. A similar quote by Ferdinand Porsche claimed "the perfect race car crosses the finish line in first place and immediately falls into pieces."[5]   [End Quote}   By Engineering's  own definition then; the AFM and Torque Converters, 4-5-6 clutch assembly of the 6L80E, and a dozen other common chronic parts and systems failures are "UNDER ENGINEERED". And by their own definition done so with INTENT. Ya can't have it both ways OEM's.
    • Everything you need to know..... https://www.gm-trucks.com/forums/topic/198157-2014-2017-dl8-dl3-towing-mirror-upgrade-–-mirrors-explained/
    • I was in Utah this week attempting a bow hunt in the Wasatch mountains with friends.  On the evening of the first hunt, making my way across a ridge to a friends camp, the upper control arm on the driver's side separated, the CV axle got trashed, and the wheel was dang near at a 45 degree angle to the ground.  I was able to get it towed off the mountain and into town about 3:00 am, and spent the remainder of the night in an O'Reilly's parking lot.  Luckily, there was a Chevrolet dealership not to far away so I was able to get to the dealership and pick up a new CV and UCA.  It would have been a few days before they could have gotten to the truck and I brought tools with me on hunt since it was a two day drive to get there, so I did the repairs myself in the O'Reilly's parking lot.      What's interesting is that the UCA ball joint didn't break, it just popped out of the bottom of the UCA.  There was VERY LITTLE evidence of grease on the ball joint or in the socket, and you could see where the ball joint had warbled out part of the socket over time.  I guess that's what happens over 186K miles of use :)   Big Kudos to O'Reilly's for letting me work on the truck in their parking lot.  However, they made a $150+ off of me from the purchase of various tools, so I guess it was in their best interest anyways :)   Getting towed off the mountain.   UCA Ball Joint Socket   Trashed CV   Suspension disconnected and UCA and CV Removed   New UCA and CV installed with the suspension buttoned up.
    • My family still laughs at me when they see me drive up in the minivan. Same with less than a V-8 truck. It helps that I have choices. I don’t think I could only have a minivan as the one and only vehicle as much as I like it. And I wouldn’t pass up a good buy on an older V-8 reg cab GM truck. Could you live Raven as the only ride?
