Good evening, I'm looking at a 2001 Chevrolet 2500HD 4x2 with 120000 miles on it. I'm just looking for advice on what potential problems to look for.
Thanks
God's blessings
What engine/transmission? Where do you live?
Kinda need more details here. Lots of it depending on those type of things.
Brake line rust, cab corner and rocker rust, wheel well rust. Gas engines are prone to valve cover leaks and oil pan/rear main seal leaks.
  • 2 months later...
I've got 350000 miles on mine still starts every morning and get me to where I have to go. Injectors make noise sometimes.  Still goes. Through mud belly deep.
    • *Your
    • I'd guess that it's because they are Mann-Hummel filters since about 2016, they own Wix and are mostly all made in China now.
