I purchased a pair of Lasfit LED switchback 5202 fog light bulbs for my 2014 Sierra.  All of the forum posts I found regarding Lasfit were positive and I am happy with the headlight bulbs I purchased from them.  My issue is that I can't get the fog light bulbs to securing into the OEM housings.  Any slight vibration or pressure pops one of the clips out and I believe they would fall out during normal driving.  I communicated with Lasfit customer service and other than adding or removing O-rings, they don't have much more to offer.
I like the switchback feature and want to give them a chance if I can figure out how to secure them.  Just wondering if anyone has had a similar issue and any solutions.
Thanks in advance for any feedback.
