Hi guys,
I installed the Eibach Pro-Truck Coil-Over Kit  Stage 2 to my 2023 Silverado regular cab.
With the coilovers at the stock adjustment the truck drives pretty good, firm but comfortable, the thing is that at this height the truck is still 1 inch lower at the front, so I went ahead and adjusted the coilovers to level the front... But now the truck is not as comfortable.
I was thinking about adjusting the coilovers back to stock height and add a 1 inch spacer, anyone has done this? Top or bottom spacer?
I also installed cognito UCAs.
Thanks
Probably not enough suspension droop. The upper control arms are probably right at or close to their limit stops.
Lowering the coil over shock and putting a block in its place will do the same thing.
Edit: Just saw you have different UCA's not sure if it gives more travel or not.
Edited by asilverblazer
    btm
    btm
  • Who's Online   5 Members, 1 Anonymous, 1,333 Guests (See full list)
