Hello everyone, new to the forum, came here looking for some help with my trucks latest electrical issue, I have a 2016 3500 4 foot long box dually  high country if that’s needed to assist. Anyway the truck has been coming up with the message something like action required “open and close drivers window”, I just ignored it. After a few days  the power window for the drivers door would not work if the door is open, but would work closed.  A few days after that, I also noticed the function to unlock the doors from the drivers control would not work regardless of the door being opened or closed, but I could lock them without issue from any door position. The truck also as of yesterday says “door open” and will not turn the interior light off. (Not necessarily in relation to this issue but 2 weeks after purchasing this truck in 2018 the passengers side mirror reverse light has decided to turn on and remain on anytime the key is in the ignition, regardless of being in drive or neutral or reverse-not sure if that’s prevalent to the new issue as it occurred years ago)  After searching through some of the wealth of information you all have created on here I decided to join in search of help, I have found some things to attempt, 1 being to check all grounds on the truck- so I have done that and found one to be heavily corroded going to the starter and I have fixed it, the second fix was to pull the doors wiring connection and look for oxidation, I found the connection to be perfectly clean. 3) was to ensure all connections to the battery are tight and without corrosion, all were. However after all of these attempts to fix, I now have found the message to “open and close drivers window” is gone, but my switches for driver window and unlock of doors still do not work along with the “drivers door open” message consistently being displayed. At this point I’m thinking of replacing the switches for the windows and door locks, but was curious if anyone could point me in any other direction to test them, or try anything else! Any help would be great, thanks y’all.
    liddlera
    liddlera
  • Who's Online   5 Members, 1 Anonymous, 355 Guests (See full list)
    • If you have actually done it, there must be some secret tool or method of accessing the hidden bolt head that both manifold connections have. Two of the three bolt heads are staring at you in the face from below but the third one is covered by shielding and as far as I know only accessed by removing part of the fender well lining to gain access to it and even then its awful to access or from what I had seen of someone fighting with it on a video.    There is a reason why even mechanics that deal with the awkward or risky business of undoing the exhaust at the manifolds have done the same method others are doing with these L8T by flexing the exhaust if need be or just able to slip the pan out as I did without needing to touch hardware or pry on the exhaust. By rights the two seals should be replace when those joints are cracked loose as well.
    • Actually it was a lot more controlled then I thought it might be and that isn't actually when I spilled some oil. I had thought prior of rounding up a couple of longer bolts with the same thread to swap out for a couple of the front edge pan bolts and then leaving one bolt left in the back but loosened off and then using a suction device to remove most of the fluid, that certainly would have worked and while I do have a couple of different devices I could have used to suck the fluid, now having done the job once I wouldn't even bother. I had thought of buying one of those pressurized vessels to suck or new fluid in and would if I was doing a job like this on a few vehicles but with one vehicle I just didn't bother and I have pail pumps as well I could have used assuming the hose end would fit into that less than roomy space but being such a thin fluid it pumped well with a quart type pump and just kept the hose into the trans and kept swapping containers and repeat.    What I would change to the method I did though was first jack up just the rear of the truck to put on jack stands to allow more oil to come out of the check plug on the front of the pan ( and as I did, I made sure to put that drain plug back in finger tight ) then follow through by putting the front on jack stands. Also that I would have used a larger sized drain pan in the sense of covering an area wider/longer beyond the transmission but I didn't have one and saw someone else on a youtube video using a masonry mud mixing tub and bought one at a hardware store to use in the future. The main oopsy  I did and why I spilled some oil was all my fault as I neglected to follow my own plan, I should have let down the pan as I did to drain out the front of it as much as would come out but then scooped out the remainder of the oil with the Dixie cup I had sitting there just for that purpose as by that point there is enough room to reach right into the front of the pan and just bail it out basically.
    • Pretty easy to just remove/drop the exhaust behind the manifolds. They're in no way hard to get to. Maybe 5min of work, and you get the opportunity to put some anti-sieze on them in case anything ever comes up, you eliminated the risk of snapping a stud.
    • I let the dealer do every other oil change simply so they can rotate the tires, which is a pita at home.
    • I addition, I won't have a pan full of fluid sloshing around to get all over the place.   I am putting on the Dorman pan with the drain plug. It looks like it is around the same height. I have one of these guys to make life a lot easier.   https://www.amazon.com/dp/B09CDXJCCT?ref=fed_asin_title&th=1
