Hey everyone. Can someone point me in the direction of where I can find the post about doing the 4 piston, 13.5in front brake upgrade for my 18 Sierra 1500? I know its on here somewhere but I can't seem to find it. Basically needing the parts numbers and/or vehicles these parts came off of. Thanks guys/gals
The calipers and rotors are off the 1/2 ton T1 model trucks
Front Passenger Side Disc Brake Caliper without Pads and Bracket - GM (13545383)
Front Driver Side Disc Brake Caliper without Pads and Bracket - GM (13545382)
You need 2 of these.
Front Brake Caliper Guide Pin - GM (13539444)
Front Disc Brake Rotor (Coated) - GM (13542112)
You can also change the rear calipers to 4 piston from rear of the basic stingray corvette. Uses your existing rotor. Also requires an adapter
Edited by Homewrecker007
Is that it no adaptors , just bolt on?
The front calipers will need a 4mm spacer between calipers and the spindle mounts to center it over the rotors.
If you do the rear you can get brake calipers from a  gen 6 SS camaro those will require brackets to bolt up. I've done front and rear on my 2014 sierra and have about 10,000 miles on the new brake setup.
you know anyone that makes that?
The 4mm spacer? My dad made mine. But most people just use 2 flat washers stacked together
you got pictures of your setup when you put it on? Id like a spacer that was specially made not washers, only the best for baby girl lol
Yes, I do.Screenshot_20241124_222733_Gallery.thumb.jpg.1371d2b89574af8e2bcc2e53ad0725fc.jpg20240731_154357.thumb.jpg.2914a3c785138f31b02d2064b07a2b29.jpg20240731_154347.thumb.jpg.c385441ac5a9bcbfad29b0ef7fbd1bbb.jpg20240731_134807.thumb.jpg.a2ac99fbc4d73fad004b66cedd5e6da7.jpg
8 minutes ago, Pinnacle said:
Oh that's sex 🙌
Thank you, just FYI I didn't actually have to shave down the calipers to fit on the front.  My wheels cleared. I was just trying to make Banshee look like a bougie b!#$%.
lm running snowflakes stocks, I don't think they touch
For the most part stock wheels I think anything 20" and up clear depending on year of truck.
Also i you're going to need a new spare tire wheel. I went with the 2023 police tahoe 20x9 Steel Wheel. 20240704_135741.thumb.jpg.10c7fc53506d7f1652df85a7b3c2f12d.jpg
For anyone wondering if factory 18in wheels fit with 4 piston calipers. Yes they do fit but only with a 1/4 wheel spacer.
    • I would have to read back to get a better picture in my mind of some of the other comments and what they were using for a driving scenario they based the fuel mileage off of. That is why the fuel mileage conversation is extremely difficult to make fair comparisons from. If I was to be living in town and only driving around town, light to light and some longer stretches that doesn't have a light every block, and the usual stop at a grocery store and the bank and so on and so forth, my fuel mileage even during the summer time would be so bad with my truck I don't even want to know how bad it would be !. Then add in winter time and idling to warm it up to clear the windows and driving through snowy streets etc, large heavy trucks with gas engines have NEVER been worth crap for fuel mileage and why some little pot licker of a car with wheelbarrow tires and a 1300 cc four cylinder non turbo engine was the ticket to using a mere fraction of the fuel over a full size pickup.    By the way my truck has the 34" tires as its a HC but not the BFG KO3 tires ( that was an option for my truck but the sales guy couldn't figure out what the tires actually were so that never got on the order until it was too late to change the truck order ). So what fuel mileage your getting actually sounds good for "town driving" and with my truck when I go to town the fuel mileage keeps increasing as I get closer to town because it takes quite a while to get the driveline oils warmed up ( and why it always shows better fuel mileage on the return trip from town because its already warmed up ) but once I am in town that fuel mileage average just keeps dropping the more I mess around town and then has to recover back to something reasonable again by the time I get home for an over all average.    I'd be curious what your sticker says for the factory weight of your truck, mine is close around that 7700 lb due to the options it has. But anyway the long and short is, vehicle weight, higher rolling resistance heavy tires and a hefty driveline and a relatively large gas engine make for crap fuel mileage in stop and go scenarios, all one can do is drive it easy off the line at each stop and as my dad had said over the years, drive like a raw egg is under your foot and that's the best one can do. Years back with a carbed engine and if the carb was getting a bit out of tune etc as would the ignition system, the fuel mileage on pickups with larger engines was just awful compared to what your getting. We pay the fuel price penalty for driving HD trucks over some little vehicle, that is the reality.
    • We had two Toyota’s with that engine in the mid 80s. We had 50 gallon fuel tanks, a toolbox full of tools, an air compressor and assorted parts for our equipment. We beat those up and down pipeline ROWs until we started buying diesel trucks. Then they became parts runners and first vehicles for our teenagers first cars. Our shop Forman wrecked them both two years apart when we hired him out of high school as an apprentice. Good thing he’s an excellent mechanic. It took awhile before he could be called a good driver.
    • I have a 2025 GMC Canyon Denali.   On a trip recently the engine failed.  The dealership diagnosed a bent valve and says there is a service bulletin that indicates to 'relace the engine'.  The truck only has about 14K miles and is under warranty.   The failure occurred 5/11/2026.   So far I have worked with GM Customer Assistance and Roadside Assistance.  Evidently no engines are available and nobody will offer a date when a new one will be.   Coming up on two months with no repair or timeline and no loaner from the dealership.   GMC Customer Assistance is 'ghosting' me and keeps closing the cases I've opened with no resolution.   Hoping someone can help me on how to escalate this issue.
