Installed these Auxito LED bulbs in my Silverado 1500 headlights. These are the first set of LED bulbs that I've used in this application that have the correct beam pattern with a nice sharp cutoff like they are supposed to and I'm no longer getting flashed by oncoming traffic. The high beams also light as they should. I prefer the color, less whitish blue than previously used. I love the plug and play and how bright and good it makes my headlights look. No more yellowish bulb.
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,358 Guests (See full list)
