Mud Terrains or All Terrains
jr.parrish
I've got a real problem and am hoping you guys can help.  My Z71 Silverado LT currently has 285/75/16 Bridgestone M/Ts with two inch body lift. Its come time to replace them and I am at a loss for which tire to pick. I don't do a lot of offroading and do alot of highway travel. When I do go off-road however I like to have the type of traction that that my M/Ts provide. (I mostly go on the beach when I do offroad, down at Oregon Inlet on the Outer Banks of NC). I really think I want another set of M/Ts but I'm not sure if BFGs would be better than my current Bridgestones. Also I am thinking about BFG All Terrains. I would really appreciate any guidance you guys could provide.
Thanks,
Justin
