Hey there,
I have 2008 Chevrolet Kodiak 6.6 LMM 4500 4WD . Trying to identify my axles and have been coming up short.
Rear: Looks like I have a 13,500lb Dana S110 SPICER axle. 5.13 ratio based on what my spec sheet from GM says. Spicer is stamped on the housing. Aluminum stamp says S110-L Not sure what that means exactly?
Front:????? Spec sheet just says 8,000lb (AWD) Front Driving. Very vague. I called the dealer and have had no resolution. What I see on the cast is REV-D, 53066, 169-7, 080103 and it has a cover with 12 bolts and no drain.
Can anyone shed some light on this? I'm sure I'll have a few questions.
I am the 3rd owner and from what I've seen and been told, everything is OEM and has not been swapped or modified.  I have called the dealer, went over the spec sheet, spoke with axle retail stores and no luck.
Thanks for the help in advance!
Jason
Rear axle is a Dana S110, I believe that was the only axle available on the 4500's.  Front axle on the TopKick and Kodiak 4X4's was usually the Dana 70F.  Regular off-road shops probably would not know what to do with this thing, try asking a commercial medium duty truck place.
On 8/24/2023 at 9:21 PM, nothingfacelv said:
Hey there,
Jason
On your build sheet, which RPO codes are on there for the axles?
Rear codes could be GL4, HD2, HD1 or HPK.
    ballencd
    ballencd
  • Who's Online   0 Members, 0 Anonymous, 440 Guests (See full list)
