I’m trying to figure out the difference between Bilstein 5100s for my 2022 Silverado LTD Custom (My truck is a non-trailboss, normal ride height).
Does anyone know the difference between part # 24-309509 and 24-293297?
My goal is to get my truck to be at a trail boss ride height.
thanks in advance!
Edited by fondupot
thanks in advance!
It's compressed height.  The shocks are designed to be used on 0" lift to whatever height.
The 24-293297 is designed to work for stock height regular trucks but can be set to add lift.  Collapsed length is 16.28".  The 24-309509 collapsed length (17.58") is taller to get to the stock front height of a Trail Boss/AT4, and then obviously lift on a TB/AT4.
Edited by newdude
  • Thanks 2
Thanks @newdude
I ordered the 24-309509 the other day and just noticed this morning the other part number. So I should be ok installing these on the tallest setting to get my desired lift?
Update. This is what the folks at Shock Surplus just sent me.
24-293297 is for the base models.
24-309509 is for only the Trail Boss.
I guess I’ll return the ones I bought and get the correct part #.
6 hours ago, Hoopstar said:
I set them to the highest position to get 3.1" total lift in the front.
Yea, I don't want to extend them up that far. I am looking to be right at ~2" all around. Trucks sits pretty level front to back now, but its just too low for most of the job sites I go on.
Shock Surplus is doing me a solid and exchanging the shocks out free of charge.
  • 2 years later...
On 10/30/2023 at 9:27 AM, Hoopstar said:
I used the 509 part # on my non AT4 truck and they worked fine, get extra lift out of them.
I have a '25 RST Duramax and could get my hands on a set of very cheap, almost new x509 (intended for the trail boss)
Looking for a 1.5" lift/level in the front - if I get these and install at the lowest setting (i.e. no lift), would I end up with 1.5 or 2" of lift?
    DaleB
    DaleB
  • Who's Online   2 Members, 0 Anonymous, 1,366 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
