Ultrasonic Back Sensor
Hi, new to GM-Truck.Com
Have a 03 SLE ext Z-71 with a Leer cap on back
Parking spots are getting small by the minute!
Is there an after market system out there, like they a have on a Caddy?
Why GM goes not have it on trucks but on car is crazy!
Thanks
  • 4 weeks later...
An even cheaper way is to keep your hitch in the receiver and just "force" your way into those tight parking spots. :cheers::D:D:thumbs:
Just kidding.
I drive in Canada, not France
LOL
An even cheaper way is to keep your hitch in the receiver and just "force" your way into those tight parking spots. :smash::smash::smash::smash:
Just kidding.
:D
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 970 Guests (See full list)
