Get your 1500HD Specs here!
After web surfing and emailing back and forth with AAM, NV, and GM here is the start of some hopefully useful factory specs, enjoy and feel free to add:
Engine: LQ4 V8: 6.0L (5967cc), Compression Ratio 9.4:1, Bore x Stroke
101.60 x 92.00mm, 300hp @ 4400rpm, 360ftlbs. Torque @ 4000rpm.
Transmission: 4L80E: (MT1) Max. Engine Torque 440ftlbs, Converter Turbine size
310 mm, Gear Ratio’s 1st-2.482, 2nd-1.482, 3rd-1.000, 4th
0.750, Reverse 2.077.
Transfer Case: NV 246: 86lbs, Oil Fill Capacity 5.1pints/1.9liters, Max. Torque
Capacity 2281ftlbs/3093Nm.
Front Diff: AAM 925: 235mm Ring Gear, Axle Torque Capacity 6300Nm, Gear Ratio
Range 3.42-4.56.
Rear Diff: AAM 950: 240mm Ring Gear, GAW rating 2700kg, Axle Torque Capacity
6800Nm, Gear Ratio Range 2.93-4.88.
    Selfman
    Selfman
  • Who's Online   3 Members, 0 Anonymous, 414 Guests (See full list)
