I have a 21 Yukon w almost 40k miles on it now and the rear end is having issues. At slow speeds after the vehicle has sat over night, the rear end locks up until we get a mile or 2 on it. After that, it drives normal. It makes a grinding whining noise like a 4wd making a 90° turn. Fluid was full as well.
Dealer called and said only the fluid has to be changed and no damage was done to the diff. I would've thought after all the grinding and whining noises sometimes would've been damaged. Is changing the fluid only putting a Bandaid on it?
I have a 2021 Tahoe. It had been making a noise for almost a year. The dealership kept saying they couldn’t get it to recreate the noise over and over again. At my last service the noise was really loud, they heard it and said that it just needed differential fluid changed. Brought vehicle home, noise was much worse and I was almost at my 60,000 mile warranty. Took Tahoe back to dealership and after 4 weeks it was determined it needs a new rear end. And now the issue is getting one because apparently none are in stock. Dealer offers no loaner cars, GM has no policy on rentals other than they may reimburse up to $50 per day. We are now on week 7, no rear end and car is still sitting. Very disappointing!!!
Edited by HollyMillerBopp850
  • 7 months later...
Here is the solution to this common problem i fixed my 2021 suburban with the following 3 products and saved thousands because after dealing with this problem for over a year i was going to buy a new differential but before I pulled the trigger I decided to give this cheap solution a try and it worked 100% i have zero noise or vibrations it drives perfect 👌 I love my car again. Make sure you get 2 bottles of the ACDelco 10-4091 because the differential fluid capacity is almost 2 quarts.
easy DIY project just need a little hand pump to put in the new fluid after draining the old fluid. drain plug is located at the bottom and fill up plug is at the back of the differential.
Dealerships are going to hate me for this tip Thank me later 😆
IMG_0541.thumb.jpeg.384dc74eefaf3060e6a6099d99dd01b4.jpegIMG_0542.thumb.jpeg.020ddf621060e3cd8744f9eb95946f83.jpeg
7 hours ago, 20SierraL8T24 said:
After 3 fluid changes with absolutely no improvement, they ordered a complete rear end.
Under warranty?  If not try my solution above
Dans l'ensemble, nous voudrions exprimer une fois de plus notre gratitude pour avoir fourni une expérience en ligne aussi agréable. Lorsqu'il s'agit de sélectionner un casino en ligne https://casino-blitz.com/ intrigant qui offre des bonus et des promotions fascinants, Blitz Casino est une option de choix que vous devriez envisager de choisir. Il n'est pas surprenant que tant de gens aient choisi Blitz Casino comme emplacement préféré étant donné qu'il offre un programme VIP unique à ses membres et un logiciel de qualité de classe mondiale.
Have a 2022 Chevy suburban, just had to have the rear differentials replaced only 50,000 miles. Made horrible grinding noises at low speed turning left or right.  My Chevy dealership said this is the fifth one they’ve had to do.
    rayredbone
    rayredbone
  • Who's Online   0 Members, 0 Anonymous, 510 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
