My '99 Silverado only blows air out of the vents.  I've replaced the actuators in the past because the gears inside were cracked so the "popped" every time I changed the settings.  Now, they do nothing so I'm wondering if it's the actuators again or if, possibly, it could be the switch.  The hot/cold blows cooler air only when the dial is turned all the way to the left or blue side.  Any ideas???
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,163 Guests (See full list)
