I'm a newby to the forum and to Chevy trucks. I just received a 2004 Silverado 4X4 for work. Great truck! Don't hold it against me, but my personal truck is an F350, dually, 4X4. My Chevy work truck may will convert me to Chevrolet.
How can I disable/disconnect that #^%$! chime that dings when I leave the door open and the key in the ignition? I frequently am out of the truck and leave the door open so that I can hear the 2-way radio (as well as the truck radio). The truck does not have meue button for memory settings. Any help will be appreciated.
Carl
I just click the latch down on the end of the door. Just remember to unlatch it before you close the door. May not be a good option if you are in and out quickly though.
